turtles_1968
#1 Posted : Thursday, January 6, 2011 3:52:51 PM(UTC)
turtles_1968
Dryer runs but have no heat. no lint blockage. Can't find where the fuse is?? Please help.
Lori
#2 Posted : Friday, January 7, 2011 3:40:07 AM(UTC)
Replacement parts for WHIRLPOOL SEDX600HQ0 | AppliancePartsPros.com
First check the power.
Try flipping the breaker off/on slowly a couple times, sometimes you can loose half the line without actually tripping the breaker.
The heating coil requires the full 240 volts.
If this does nothing, check the voltage at the plug
L1 to L2 should be 240 volts
If OK
If OK
[COLOR="Red"]Be careful as 240 volts is lethal !!! [/COLOR]
FYI: The unit has 2 thermal fuses but Item 23 in Section 3 kills power to the motor.
The thermal fuse (cut-off) for the heating element is item 6 in Section 3.
Check the heating coil first for continuity, then the thermal fuse.
If the thermal fuse is blown:
Check the heating coil.
Unplug the unit and both wires to the coil.
Check it with a meter, should be around 10 to 12 ohms.
Then check from each side of the coil to the case/frame, both should be infinite ohms (open). If not the coil may have sagged or broken and is touching the case. This can cause it to run on high and the thermostats cannot regulate it so the thermal cut-off blows.
The hi-limit should have regulated the temperature so the fuse did not blow.
That is why the replacement is a fuse and a hi-limit.
Note: That unless there is another problem in the unit the hi-limit should never have to open. It is just a safety device with the fuse being a backup safety device.
Just in case it is not a grounded element.
With all the below the high limit will also have to be replaced.
Check that the belt is OK.
Check the seals (drum etc) in the unit. The air is pulled over the heating coils, through the drum and pushed out the exhaust. So any large seal leak will pull in room air and the cycling thermostat on the blower will run the unit hot.
Check that the lint filter is not coated with fabric softener residue which greatly reduces air flow.
Check/clean your vent system.
Check/clean the blower wheel.
If all OK you may want to replace the cycling thermostat as it's contacts may not be opening (welded sh
