3 Pages<123>
Screamin Eagle
#11 Posted : Friday, December 31, 2010 12:13:55 PM(UTC)
Screamin Eagle
Gene, your right, I thought it would be a simple fix but I just got sucked into the parts vortex....I installed the safety thermostat but that doesn't seem to be the fix either, any suggestions on what to try or test next? Here's my current list of new installed parts-
safety thermostat
230- thermostat
407- thermostat
717- igniter assm.
552- heat detector
729- dual coil
731- main coil
Gene M
#12 Posted : Thursday, January 6, 2011 11:11:09 PM(UTC)
I did not get clear if you replaced the thermal fuse (#507 on the diagram)?
Screamin Eagle
#13 Posted : Friday, January 7, 2011 8:13:22 AM(UTC)
Screamin Eagle
Gene, yes, the thermal fuse aka safety thermostat has been replaced.
#14 Posted : Friday, January 7, 2011 1:54:16 PM(UTC)
Gene,
I'm sorry to say it but I'm stumped.
I asked other experts working on the forum to look into it. May be someone else will help you out better.
Screamin Eagle
#15 Posted : Saturday, January 8, 2011 7:02:50 AM(UTC)
Screamin Eagle
Thanks Gene I appreciate it.
Gene M
Screamin Eagle
#16 Posted : Sunday, January 9, 2011 9:06:00 AM(UTC)
Screamin Eagle
Well I'm still at the beginning from where I started, sometimes the dryer will run with hot air and sometimes it just has cool air. What part should I be looking at next?
#17 Posted : Tuesday, January 11, 2011 3:14:25 AM(UTC)
I would wiggle the timer knob and see if it is intermittent. If so it may have bad contacts. You can take the timer apart to check for burnt contacts. Timer AP2042833 Lots of times the contacts can be cleaned with fine emory paper.
Screamin Eagle
#18 Posted : Tuesday, January 11, 2011 3:14:15 PM(UTC)
Screamin Eagle
Thank you RichHappy I will try that.
Gene M
Screamin Eagle
#19 Posted : Saturday, January 15, 2011 11:19:03 AM(UTC)
Screamin Eagle
I cleaned the contacts on the Timer, I'll let ya know what happens this week.
Thanks,
Gene M
Screamin Eagle
#20 Posted : Friday, January 28, 2011 12:43:44 PM(UTC)
Screamin Eagle
Still with intermitent heat but have noticed the timer is now "sticky" doesn't progress to less and less time
GENE please e-mail me your address i'd like to buy ya a cup of coffee and some doughnuts (DD card) for helping me out
Gene M
Guest (7)
3 Pages<123>
