johnny wen
#1 Posted : Wednesday, January 5, 2011 1:34:21 PM(UTC)
johnny wen
Hi please help
The light bulb went out inside the the microwave.
How do I get to it? Do I remove white grill from top. Then remove small rectangular filter and then the lamp cover?
Is it all accessible or do I have to drop the entire microwave
Joe / APP Team
#2 Posted : Thursday, January 6, 2011 10:34:24 AM(UTC)
Joe / APP Team
Rank:: Advanced Member
Originally Posted by: johnny wen Go to Quoted Post
Hi please help
Johnny,
You're on the correct track,
Here's the procedure from the service manual,and the part number you need,
Part number: AP3132067
IMPORTANT:
When you work on the microwave
oven, be careful when handling the sheet metal
parts. Sharp edges may be present, and you
can cut yourself if you are not careful.
1. Unplug microwave oven or disconnect power.
2. Remove the air grille.
3. To change the oven cavity lamp, lift the tab on
the cover to access the lamp.
4. Unscrew the lamp from the socket. There will
be a dab of silicone that is intended to keep
the bulb from loosening in the socket during
shipping. Be sure to clean off any loose silicone
from the socket before installing a new
lamp.
Reverse procedure and test unit.
Good Luck,
johnny wen
#3 Posted : Thursday, January 6, 2011 12:15:56 PM(UTC)
johnny wen
Thank you so much
is it a common problem if the inside bulb goes out. I hope its not a control panel issues, etc.
Joe / APP Team
#4 Posted : Friday, January 7, 2011 5:38:33 AM(UTC)
Joe / APP Team
Thank you so much
Johnny,
Yes, it's more common than a bad control board.
A lot of people, don't bother replacing them, And in most cases, it's a more involved procedure.
I'm sure you'll be OK,
Good Luck,
microwaveexpert
#5 Posted : Friday, January 7, 2011 5:56:01 AM(UTC)
microwaveexpert
You would normally need to remove the outer cabinet (cover) to get access to the bulb. The covers found inside are more likely to be the waveguide cover and nothing to do with the lamp. If you need a bulb or waveguide cover check out Microwave oven spares, microwave cookware, kitchen appliance spares : Buy from Kitchenwareonline.com : The microwave oven experts.
microwave oven Fuse blew, replacement blew too after 1'2 second. (Microwave Repair)
by paulmars 5/26/2022 2:21:47 PM(UTC)
Panasonic 1250W microwave oven (Microwave Repair)
by Guest 11/7/2021 5:13:30 AM(UTC)
No Beeping - Emerson Microwave Oven (Microwave Repair)
by Wkolosi 1/18/2021 4:08:40 AM(UTC)
Whirlpool microwave ovens countertop (Microwave Repair)
by boxershubhammm 9/23/2019 10:06:07 PM(UTC)
LG Microwave Oven (Microwave Repair)
by KJ43026 1/10/2018 4:53:45 PM(UTC)
Our Microwave Oven stopped working (Microwave Repair)
by Artista 12/26/2016 8:32:57 AM(UTC)
Microwave oven LATCH (Microwave Repair)
by MAKODOG 4/18/2016 5:32:27 AM(UTC)
by blbweston 4/21/2014 11:13:01 AM(UTC)
How To Change The Bulb In Microwave Oven Combo (Oven Repair (including Ranges and Cooktops))
by Lax21 2/1/2014 10:21:18 AM(UTC)
by JOSEPH MONNEY 11/13/2013 10:57:58 AM(UTC)
by JOSEPH MONNEY 11/13/2013 10:47:08 AM(UTC)
by johnny wen 6/20/2013 6:39:36 AM(UTC)
GE Profile microwave oven (Microwave Repair)
by alpinebucks 6/13/2013 12:47:08 PM(UTC)
Low heat from OTC Microwave Oven (Microwave Repair)
by Whirlpool OTC MicroWave 5/27/2013 2:26:18 PM(UTC)
GE Profile microwave oven - replacing the board latch (Microwave Repair)
by srduff1977 11/5/2012 9:46:52 AM(UTC)
