machine runs throught frist cycle fine but buzzs when it should start rinse cycle what needs replaced
Set it on a "COLD/COLD" cycle, and see if it buzzes during the fill.
on cold/cold water would not run in
Originally Posted by: k kelchen  on cold/cold water would not run in but will on other settings/quote]
I suspect you have a bad water inlet valve.
