The washer will fill and overflow owhen it comes to the rinse cycle:mad: . It fills and stops in the begining of the wash, and only overfills when it comes to the rinse cycle.
I saw similar post here and the answer back was to look at the dome hose. If the problem was the dome hose, would it not overfill on the first fil as well, and not just on the rinse cycle:confused: ?
Thanks in advance:)
Sounds like a timer problem.
