Richard Lindner
#1 Posted : Wednesday, September 3, 2008 10:57:56 AM(UTC)
Richard Lindner
Ordered and Recieved a replacement Water Inlety Valve -- part number2206123 for my refrigerator, Inlet valve controls water to ice maker and to cool drinking water supplied through the door. The valve is identical to the one being replaced -- except the water connections on tha old valve are all compression/farrel type fittings. The new valve has 3 water connections that are not that type and I'm not familiar with what type ther are (there's a colored sleve insive each opening and what might be some tpye of twist/lock collar on each one. Can I use this part? Do I need to modify the hoses connections and how? Where do I obtain the compatable connectors???
abadfish66
#2 Posted : Wednesday, September 3, 2008 11:37:30 AM(UTC)
abadfish66
All you do is cut the hose ends below the nut, and push the hoses into the new valve. The new fittings are a push to lock type fitting, you should feel it lock when you push the hoses in the new valve.
Hot to replace water inlet valve on GE washer dryer combo WSM2700HCWWW? (Washer Repair)
by AbbyBrickman 1/4/2016 8:36:24 PM(UTC)
replace water inlet valve (Dishwasher Repair)
by fredriny 9/2/2010 11:51:19 AM(UTC)
repair or replace water inlet valve (Washer Repair)
by richard1520 12/17/2007 10:06:04 AM(UTC)
