billwinsac
#1 Posted : Wednesday, January 5, 2011 10:24:22 AM(UTC)
billwinsac
Self clean feature does not work. All controls set to CLEAN, Timer set, start knob is out, when latch is moved to right Oven light will flash on then off, but Latch light doesnt come on, and door doesnt latch. Broiler element gets warm, but no latch. :confused:
#2 Posted : Wednesday, January 5, 2011 1:24:35 PM(UTC)
Make sure the door latch handle is not bend and the screws holding the handle to the latch are tight.
Check the lock switch link (#28 on the diagram) and the lock switch.
Here are the breakdown diagrams and Replacement parts for HARDWICK EPF9-77A579A RANGE- S/C F/S ELE | AppliancePartsPros.com
billwinsac
#3 Posted : Wednesday, January 5, 2011 2:14:03 PM(UTC)
billwinsac
Thanks for your input. I will let you know as soon as I can check the Handle and link. I was sort of thinking along those lines.
