mjcoxwel
#1 Posted : Tuesday, January 4, 2011 5:24:14 PM(UTC)
mjcoxwel
This is a duet dryer- how do i get to the screws to tighten up a dryer blade that has loosened. Is it through the back and is it a pain once the back is removed?:rolleyes: Thanks for any help you can offer!
sidfink43
#2 Posted : Wednesday, January 5, 2011 5:37:16 PM(UTC)
sidfink43
I assume you are talking about the blades inside the drum. If you take off the top of the dryer you should be able to get to the screws that hold them on.
mjcoxwel
#3 Posted : Wednesday, January 5, 2011 6:59:59 PM(UTC)
mjcoxwel
yes i was - thank you for your post I will give it a shot
