indyjones
#1 Posted : Monday, September 1, 2008 4:50:08 PM(UTC)
indyjones
Hi everyone,
So all of a sudden my washer won't fill. I've checked the screen, hoses, inlet water and they are okay. I've pulled out the water valve and both the hot and cold valves don't seem to let water pass when I turn on the washer cycle. I'm thinking it is highly unlikely that both valves failed at the same time, so perhaps there is a common interlock that has failed...any ideas?
TIA
indy
indyjones
#2 Posted : Monday, September 1, 2008 4:54:05 PM(UTC)
indyjones
I should say that the washer works on spin...so power is okay....and doesn't fill on cold, warm, or hot.
