Marc Ernst
#1 Posted : Saturday, January 1, 2011 9:45:06 AM(UTC)
Marc Ernst
None Of the burners are working on the cooktop of my stove. I cannot locate info on any of my documentation for it to tell me what the voltage output on the transformer should be. Do you know what it should be.
#2 Posted : Sunday, January 2, 2011 4:49:45 AM(UTC)
Replacement parts for FRIGIDAIRE PLES389ECD Frigidaire/electric Range | AppliancePartsPros.com
I do not have any info on a slide-in unit but with luck the following should give you some info assuming that the slide-in and free standing units are basically the same when it comes to the controls.
http://frigidaireservicetips.com/pdfs/477_5.pdf
kayakcrzy
#3 Posted : Sunday, January 2, 2011 5:06:10 AM(UTC)
kayakcrzy
I am wondering if you have a power problem. You might want to check where the power comes into the stove. Alot of times, that is where, the wires burn. Tom ApplianceEducator.com
Marc Ernst
#4 Posted : Sunday, January 2, 2011 9:03:00 AM(UTC)
Marc Ernst
Originally Posted by: denman Go to Quoted Post
Thanks,
I will look this link over and see if I locate what my problem might be.:)
Marc Ernst
#5 Posted : Sunday, January 2, 2011 9:05:18 AM(UTC)
Marc Ernst
I have checked where the power comes in and all checks out good there. No burned wires. Thanks anyhow.:confused:
kayakcrzy
#6 Posted : Sunday, January 2, 2011 12:10:28 PM(UTC)
kayakcrzy
Did you take a voltage reading?? All burners don't go out at once!! There has to be a power issue. Tom ApplianceEducator.com
Guest (4)
