AppliancePartsPros.com
Appliance Repair Help
Washer Repair
Washer suspends when working. It need a flat to 'wake up"
My washer seems to be too old. Sometime, it falls 'asleep' when it works. In order to 'wake' it, I should 'flat' the washer door, or, open the washer's door and shut it down heavily. I do not hear special noise or get special smell from it.
What's wrong? Which part should I order?
Thanks.
At what part of the wash cycle does the washer stop in?
You may have a bad lid switch.
Thanks, ApplianceJunk My washer often stops in Rinse. Sometime, it can not enter Rinse circle and I have to put the cycle back to re-start. Sometime, the washer can not drain the water and stop, re-start will help it. Originally Posted by: ApplianceJunk  At what part of the wash cycle does the washer stop in?
Washer Repair
