hosic
#1 Posted : Saturday, January 1, 2011 6:24:04 PM(UTC)
hosic
Hey guys, dishwasher stopped working last week. LED controls were blank and could not turn it on. Diagnosed it to the bi-metal non-reset fuse. Replaced it and all was well for about three loads (4 days time). Today i went to do a rinse only mode and tried turning on heated try, it would just flash and not stay solid. Thinking it was weird i just let it to. Came back 10 minutes later and the control panel is blank again and cannot turn the unit on. I have not took apart to check anything out but anyone have a idea where to start?
Thanks in advance!
ApplianceJunk
#2 Posted : Saturday, January 1, 2011 7:55:31 PM(UTC)
ApplianceJunk
If the new thermo fuse you replace come with new wire leads make sure you use them.
What often takes out them thermo fuse is bad connection on the wires that plug into them so the new thermo fuses comes with replacement wire connections.
kayakcrzy
#3 Posted : Sunday, January 2, 2011 4:10:38 AM(UTC)
kayakcrzy
I have seen this many times, where the fuse blows, and then works a few times, then gone again. Replacing the board. Part # W10084141, and the fuse, is what has been working for me. I have gone back to people's house's only to replace the board, after going the first time, to replace the fuse. Tom Appliance Educator, Appliance Parts, Washer and Dryer Parts, Refridgerator and Freezer Parts, Stove and Oven Parts
