Cujok
#1 Posted : Sunday, August 31, 2008 2:22:55 AM(UTC)
Cujok
Hi everybody, this is my first post. I have a 20+ year old Kenmore freezer. It has been working great until yesterday. I started hearing a clicking noise coming from it. I pulled it away from the wall and the clicking noise was coming from a relay attached to the compressor. The compressor was very hot, about 165 degrees and was not running. I unplugged the freezer and let it sit for about 2 hours. The compressor cooled down so I plugged it back in and the compressor fired up and it started running. I let it run for quite some time but it never shut off. I checked the temp inside the freezer and it was about 4 degrees. The compressor was very hot again. I turned the thermostat down but it still didn’t shut off. I turned it all the way off and it finally stopped running. It seems as though the thermostat has stopped working. Any suggestions/comments would be appreciated.
Thanks - CujoK
libertyappl
#2 Posted : Sunday, August 31, 2008 6:23:45 AM(UTC)
libertyappl
Sounds like your thermostat(temp control is bad) would suggest replacing that part. It is normal for the compressor to be really warm.
kenmore freezer won't stop running (Refrigerator & Freezer Repair)
by d_rogers@charter.net 1/29/2013 2:03:43 PM(UTC)
Frigidaire freezer won't stop running (Refrigerator & Freezer Repair)
by CrazyforYeshua 8/2/2012 5:02:03 AM(UTC)
WHIRLPOOL Freezer won't stop running (Refrigerator & Freezer Repair)
by thatguybry 6/7/2010 8:28:15 PM(UTC)
Refrigerator/Freezer Won't Stop Running (Refrigerator & Freezer Repair)
by crib_troll 1/16/2010 4:49:00 AM(UTC)
