During the installation of this dishwasher one wire in the yellow wire bundle going from the door to the sensor in the bottom of the unit was cut. There was power at the unit when this happened and it seemed to short out. Pulled the unit out and repaired the broken wire, but when attempting to power up, have got no power. There is power at the power cord but none beyond that. Is there a fusible link somewhere that can be reset or rreplaced as needed. Would appreciate any help.
If it is less than a year old call a authorized service company. Better to do that even if you have to pay for the call than to void your entire warranty dur to working on it yourself. Nat
