x-dea
#1 Posted : Thursday, December 30, 2010 11:38:36 AM(UTC)
x-dea
For the past 6 or 7 months the water dispenser would not work for a few hours, then it worked. After that it wouldn't work for a day or so, then it would start working. Then, it wasn't working for a couple of days so I disconnected the coupling at the freezer door hinge and fed a thin wire up the tube and poked around for a while. The water started dispensing. I thought the problem was solved. Well, it lasted overnight and now no more water flow. It hasn't worked since.
I read on this forum someone leaves the door light on and that seems to work for him. As of this writing my door light has been left on for about 1/2 hour. I'll see if this works.
For those who might be interested, I'll post the results.
Wish me luck.
