You have been a member since:: 8/29/2008(UTC) Posts: 3
G'day,
I'll try and explain best I can. Bought a new control assembly that is not quite a perfect match. I have 2 plugs that don't match up with new assembly. One has 2 yellow leads that go to a spray botton. (not really concerned about that one) The other has a black and a white lead running from it and the plug has openings for 3 prongs. It plugs into CN3.
There is not similar place to plug this one in??
Any ideas what this is for and how important it is? Maybe some kind of work around?
Thanks!!!
Is this the part# you got for it? WH12X10138
FYI the whit and black is your power into the board, so it is very important.
There's your problem, if you posted the correct model# you need the WH12x10138 board. You got the wrong board.
Originally Posted by: abadfish66 There's your problem, if you posted the correct model# you need the WH12x10138 board. You got the wrong board. I just ordered what appliancepartpros told me was the correct part. Thanks for the info. Appreciate the help :D
