Looking up into the area where the ice comes thur the outside rubber flap door, looks like some mold has start up there ? How can we take that section off to clean that area ? or is there something that we can spray up into that area to cleaned it ? Thanks
1. Use a screwdriver to unlock the tabs at the bottom of the control panel. Slide the bottom out and down. 2. Disconnect the wiring harness connectors. 3. Remove 4 Phillips screws in the door dispenser housing. 4. Slide out the housing and disconnect the target switch and dispenser light connectors. 5. Spread out the locking tabs and remove the switch. 6. Push the chute duct door locking tabs back and raise the assembly above the locking tabs. 7. Push the lower armature locking tabs (under the assembly) back and lift up the entire assembly. Gene.
