dgodin1961
#1 Posted : Tuesday, December 28, 2010 6:56:53 AM(UTC)
dgodin1961
Changed the thermal fuse behind control panel after the oven died during cleaning cycle. Now Top oven is not working - Bottom works fine.
Joe / APP Team
#2 Posted : Wednesday, December 29, 2010 6:18:10 AM(UTC)
Joe / APP Team
DG,
You may have an open element thermal fuse,
Part number: AP3879224
Located on the back of the oven cavity,or a broken, burnt wire to the elements.
The easiest way to check,
*** This is a LIVE voltage test, so be careful ***
Turn power off the the oven,
Dismount the bake element from the oven cavity, and slide element out as far as possible, leave the wires attached.
Restore power and program a bake cycle,
Check for 220 VAC across the terminals of the bake element,
If you have the 220 vac, you have a bad bake element.
If you have 120 vac you have lost a power leg,
and will need to acces the back of the oven, to check the fuse for open and wiring for damage.
Good Luck,
