Some time the dryer works and some times it doesn't , I took it apart yesterday and cleaned it tried it it worked fine when i put it back together and put a load in it it wouldn't work then i waited couple of hours and tried it it worked and it dried the load fine. Can someone please explain what is wrong. Thanks a million.:p
Check your wire connections make sure they are snug. Nat
My dryer is having the same problem if you find the cause please let me know what it is.If I get an answer I will let you know.:confused:
