raptor01
#1 Posted : Thursday, August 28, 2008 4:20:17 PM(UTC)
raptor01
trying to put dryer back together. belt seems a bit loose. how does it need to be routed to be tight?
Also, how do you know when the thermostats are bad?
libertyappl
#2 Posted : Thursday, August 28, 2008 6:38:29 PM(UTC)
libertyappl
You can check the thermostats with an ohm meter, test for continutiy. I'll try to locate a picture of the belt route, might be easier thatn trying to type it all out.
libertyappl
#3 Posted : Thursday, August 28, 2008 6:53:50 PM(UTC)
libertyappl
Ok, I couldn't find a good picture and I hope you can overlook my crude attemp to tweek a picture. I hope it helps you.
Nat
libertyappl attached the following image(s):
raptor01
#4 Posted : Friday, August 29, 2008 1:39:17 PM(UTC)
raptor01
I figured it out. The belt goes on top of the idle roller first and then goes around the motor and back up around the tumbler. It's kind of a pain to put on but it is snug afterwards.
dryer belt installation, no pulley (Dryer Repair)
by flamingo 12/12/2012 7:19:25 AM(UTC)
dryer belt installation (Dryer Repair)
by dick taylor 4/22/2011 1:54:45 PM(UTC)
Frigidaire Dryer Belt Installation (Dryer Repair)
by Shareall 4/4/2010 11:40:54 AM(UTC)
