vintris
#1 Posted : 17 years ago
vintris
Do you REALLY need to buy the whole kit for a leak?!
We have a leak at the flange between circ pump and its housing on a SHU9925 Bosch dishwasher.
It seems the only way to get parts for that is to buy the entire kit (AP2802376)
Is that really true or necessary?
Pete
#2 Posted : 17 years ago
Yes Pete, you do have to buy this kit because Bosch does not sell the seal separate.
vintris
#3 Posted : 17 years ago
vintris
Thanks Gene,
would you recommend to use all teh parts out of the kit?
I assume Bosch put that kit together for a reason.
Is this a typical problem causing leaks into the floor pan?
I'm still not 100 sure that I found the leak. Indicator is sediment around the lower part of the flange.
Thanks again
Peter
