Hi Ray, Before you'll make the final decision perform all tests recommended in the tech sheets attached to this reply. Gene.
Hey Gene, Thanks for the info. The tech sheet says to use test 4 if you are getting an f2 code. The test says it is if you do not see lights or hear beeps. When I plug in the washer about half the lights flash and the machine does beep, all while I am getting the f2 code. any sugestions? Thanks Ray
Ray,
Double check all connections and if it would not help then probably the user interface has gone bad.
Gene, I have read so many post and some are old...can you please tell me the correct part number to fix the F1 error on a Sears Oasis Elite, Mod 110.27032603. We get the error on every single load that is washed with 21 minutes left in the cycle. I have been jerked around so much by Sear I am going to repair it myself. Is the part listed on APP (AP4360738) the correct one? You can reply to this directly or my personal email: wcstanley@cox.net. Thanks! Bill
Yes Bill. The part number you posted is the correct part number.
Thanks Gene. I order the part, it came in very quicky. It was easy to replace and works like a champ! Now, when it rains it pours. My dryer, model 110.67042600, seems to get stuck in the cycle with 18-20 minutes remaining. Is there a tech sheet with any automatic tests like the washer has? I performed the same steps to auto start and it does just like the washer (with 88 showing), but nothing else. Please advise.
Bill
Originally Posted by: Bill Stanley  ...seems to get stuck in the cycle with 18-20 minutes remaining...
...Is there a tech sheet with any automatic tests like the washer has?... Bill, I'm glad to hear the washer is back in business. Does the dryer stop completely at this point or it's just the timer not advancing? Did it show any error code? The tech sheet suppose to be inside the console. Gene.
