2 Pages<12
magician59
#11 Posted : 14 years ago
magician59
You first have to discern whether the HV transformer is getting 120VAC. To do this, unplug the oven and open up the cabinet and [COLOR="Red"]DISCHARGE THE CAPACITOR[/COLOR]. Disconnect the transformer lead to the diode and isolate it from any metal contact. Plug the machine in and select a cook mode. Measure voltage at the transformer connection to the control board. If you don't read 120VAC, the problem is the control board. If you get the proper voltage from the board, the transformer is probably the culprit (a bad transformer usually makes a loud, growling noise).
neogara
#12 Posted : 14 years ago
neogara
Thnaks a lot!!! I'll do that.))
magician59
#13 Posted : 14 years ago
magician59
Let us know what you find.
neogara
#14 Posted : 14 years ago
neogara
:) ...Here is what I have found:
1. H.V. transformer has ~120VAC on primary side, resistance is within a normal range,lesss than 0,5ohmm, due to a thick wire diametr of a cupper wire used in primary winding.
2. When power has been applied to unit and secondart and filament winding are disconnected from circuits( ground, h.v.diode,h.v.capacitor, magnetron, e.t.c.) transformer still maked loud noise, but less loud, when all h.v. transformer winding wires connected to circuits. That tell me, I have a defective h.v.transformer.
3. When I checked a resistance between a socondary winding and a ground pont( a trnasfomer core case, or unit chassis) resistamce on my multimetr is 72 ohm( R=72ohm), which is low. Normaly a secondary winding aproximately has a resistanse of 100 ohms, but in my case it doesn't. So, I think I have a defective transformer! Bingo!!!:)
I want to thank you for all advices you have been given!!! I am apreciate that!!!:)
...Now I need to replace a h.v. transformer to see, if I have any other surprises!!!:) ...I hope not!!!:)
sprtfan
#15 Posted : 14 years ago
sprtfan
How did you get GE to send you the magnetron? I have a GE that will no longer heat. A local repair shop said they thought it was the magnetron but it would cost about $80 to have it fixed if I brought the microwave in and even more if I had them come out.
I'm capable of replacing the magnetron myself but they will not send it to me. Thanks
neogara
#16 Posted : 14 years ago
neogara
...I haven't replaced a magnetron yet...No need at this point...until I find out what is going on in this microwave oven...
...I replaced a high voltage(h.v.) transformer, but it didn't help...I still have the same loud sound comming from oven, when unit works. I need a further evaluation...It act, as a defective magnetron, or h.v.transformer, but that isn't the case....H.v. diode and h.v. capacitor are ok. It makes a loud souns, when only primary winding of a h.v. transformer connected to circuit and all high voltage componets are disonnected...Something going on on primary die of circuit...A line filter cheks ok...fan capacitor cheks ok...I know, PCB can't couse a loud sound in unit, if a h.v. transformer has ~120V on it's primary winding. All thermistors in unit cheks OK also...It means something else...What is it?
2 Pages<12
