oogravyoo
#1 Posted : Sunday, May 24, 2009 9:25:33 AM(UTC)
oogravyoo
I was given a Jenn-Air Quiet series DW731W dishwasher that was being replaced because of a Kitchen upgrade.. its replacing our GE hunk of Junk that was installed when we had our house built. (Jenn-Air unit was functioning perfectly when it was removed)
However the unit did not function correctly for me when I put it in, after some poking around I noticed that it was missing the Spring Return for the Solenoid pull. Once I got that on (look at image and tell me if the spring is in the correct spot) the dishwasher ran through its cycles correctly.. However there was a slow leak, I could not tell where it was coming from so I put some Food Coloring in the water and found the leak quickly after that (see image)..
What do I need to do to fix this leak, any ideas would be appreciated. I am currently laid off and would like to do this myself if possible.
Thanks,
Alex
oogravyoo attached the following image(s):
#2 Posted : Monday, May 25, 2009 4:04:30 AM(UTC)
Replacement parts for JENN-AIR DW731W | AppliancePartsPros.com
Here is a service manual, pictures are pretty dark but it should be helpful.
http://www.servicematters.com/m...ibrary/docs/16007822.pdf
Does sound like the seal needs replacing.
oogravyoo
#3 Posted : Monday, May 25, 2009 4:43:10 AM(UTC)
oogravyoo
thanks for the info Denman..
paddiwack
#4 Posted : Wednesday, December 22, 2010 10:24:51 AM(UTC)
paddiwack
Alex,
Given that your post is more than a year old, this won't help you, but may be useful for someone else. I had my Jenn Air DW760B apart to replace the flapper and figured I'd take a picture of the spring position for the forum. I assume you already figured out that the location you had it in was incorrect; you can barely make out the spring in the parts diagram, but it does show the right placement for it.
The photo below should give you a good idea of how the spring is mounted.
Jerry
paddiwack attached the following image(s):
oogravyoo
#5 Posted : Wednesday, December 22, 2010 1:27:02 PM(UTC)
oogravyoo
paddiwack,
Yea I figured it out, much easier to see it out like that :)
that picture will help if anyone has the same issue..
tnx.
