Blakes7
#1 Posted : Tuesday, December 21, 2010 7:35:43 AM(UTC)
Blakes7
Hi! I have an old Kenmore oven/range. The bake element has broken---literally broken apart. I can't find the model number anywhere. I've checked on the door, in the oven, under the range top, and in the drawer underneath. The only sticker is a warning sticker, but there are no numbers on it, except at the very bottom---PLT083-2. I've looked up bake elements on the web, and at this url is a matching one: http://www.********************...e-Range-Stove-Oven-Parts. It's the third one down. Would this one work, or is the voltage and wattage going to cause a problem? I don't want to blow up the house, or the oven, and I don't want to pay for a repairman for a simple repair. Any and all responses will be greatly appreciated. Thanks.
Blakes7
#2 Posted : Tuesday, December 21, 2010 7:40:48 AM(UTC)
Blakes7
Hi, again. I noticed the url didn't post, so the web site was ************************. com. Thanks.
Blakes7
#3 Posted : Tuesday, December 21, 2010 9:43:23 AM(UTC)
Blakes7
Hi! I've found the model number. It's---911.9344190. The serial number is---4R227800. Thanks.
#4 Posted : Tuesday, December 21, 2010 11:52:39 AM(UTC)
This should be the correct element
Part number: AP2030968
Click on the picture for more info.
Remove power from the unit.
This is very important as many stoves still have 120 volts at the element even with the oven turned off.
Undo the screw holding the element to the back of the oven.
Gently pull the element into the oven.
Remove the wires/connectors from the element.
It is a good idea to clip something to the wires (Clothespin etc.) so they do not disappear into the back of the oven before you get the new element installed.
Blakes7
#5 Posted : Wednesday, December 22, 2010 8:13:18 AM(UTC)
Blakes7
Thanks for the response. I'll order the part today. Thanks again.
Kenmore bake element stays on (Oven Repair (including Ranges and Cooktops))
by mtrammell 1/26/2010 6:26:28 PM(UTC)
