dbergquist
#1 Posted : Friday, December 10, 2010 10:39:59 AM(UTC)
dbergquist
I'm trying to convert my GE Cooktop Model JGP328WEK2WW to use LP gas. I ordered a pressure regulator and LP orifices. I have installed the orifices, but when I attempted to adjust the pressure regulator (part number AP4346295) for LP gas the spring retainer didn't look anything like the image in the installation manual. According to the manual, I need to remove the spring retainer which has a NAT end and an LP end and re-insert it with the LP in facing the unit. In the pressure regulator I purchased there are two springs, a larger diameter on held in place by a threaded plastic collar and a second smaller-shorter spring in the center of the first that is connected at one end to the inside of the regulator. I have verified with customer service that I have the correct pressure regulator so, how do I adjust it for LP Gas?
dbergquist
#2 Posted : Monday, December 20, 2010 1:06:55 PM(UTC)
dbergquist
I submitted this question 12/10 per instructions from the "live chat" representative. I was told today that I needed to re-submit to get this to the top of the question list. Can someone answer this question? Thanks.
dbergquist
#3 Posted : Tuesday, December 21, 2010 12:40:40 PM(UTC)
dbergquist
There has been no response to my question for some time. Is it unclear what I'm asking? Let me know and I'll re-frame the question.
