cpkennedy
#1 Posted : Monday, December 20, 2010 5:34:15 AM(UTC)
cpkennedy
The oven temperature is real low. Both elements appear to be working.
#2 Posted : Monday, December 20, 2010 6:11:10 AM(UTC)
Could be your oven sensor.
Here is a link with info on how to check it
http://www.applianceaid.com/elecrange.html
Also depends what you mean by "real low".
You can usually adjust the temperature plus or minus 35 degrees. See your operators manual.
NOTTI
#3 Posted : Monday, December 20, 2010 6:34:42 AM(UTC)
NOTTI
MY ADVICE IS TO CHECK THE OVEN THERMOSTAT WITH A TEST METER
cpkennedy
#4 Posted : Monday, December 20, 2010 10:38:32 AM(UTC)
cpkennedy
I mean REAL low. It's like the thermostat is not properly operating. Is that hard to replace?
cpkennedy
#5 Posted : Monday, December 20, 2010 10:40:15 AM(UTC)
cpkennedy
It's REAL low. It's as if the thermostat is not working either properly or at all. is that hard to replace?
NOTTI
#6 Posted : Monday, December 20, 2010 10:46:26 AM(UTC)
NOTTI
NO ITS QUITE SIMPLE DISCONNECT FROM MAINS LOCATE THERMOSTAT (BEHIND KNOB AND ALSO SENSOR (INSIDE OVEN A LONG COPPER TUBE WITH WIRE GOING TO STAT) MAKE NOTES OF WIRE LOCATION (USUALLY TWO) THEN REPLACE IF IT IS A GAS OVEN THEN WONT BE ANY WIRES.
#7 Posted : Monday, December 20, 2010 12:23:38 PM(UTC)
In order to provide most accurate advice we need the complete model number of the oven.
Incorrect oven temperature (Oven Repair (including Ranges and Cooktops))
by cwren 5/31/2008 8:08:43 PM(UTC)
