AppliancePartsPros.com
Appliance Repair Help
Refrigerator & Freezer Repair
refrigerator stopped working cleaned it and started working then stopped working agai
My Ge side by side refrigerator stopped working, I cleaned the coil plugged it in and an hour later the freezer was at about 0 and the refrigerator was in the 40s. Two days later stopped working again. when we first baught it new about 9 or 10 years ago the day it was delivered it would not get cool, a service man came out and replaced an elcetrical part and have had no problem since then, untill now. Could it be the same part again and if so what might that part be? thanks, Goatman.
A model number may help others help you. Sounds like you have a defrost problem. To confirm this remove the evaporator cove from inside the freezer so you can see the coils. If they are heavily frosted/iced over then you do have a defrost problem. Here is a good site with basic fridge repair info. http://www.applianceaid.com/frig.htmlCannot comment on the repair when it was new. I would need a lot more info. There are a many things that can cause a unit to stop cooling. |
THIS FORUM IS DEAD!!!!!!! |
Originally Posted by: denman  A model number may help others help you. Sounds like you have a defrost problem. To confirm this remove the evaporator cove from inside the freezer so you can see the coils. If they are heavily frosted/iced over then you do have a defrost problem. Here is a good site with basic fridge repair info. http://www.applianceaid.com/frig.htmlCannot comment on the repair when it was new. I would need a lot more info. There are a many things that can cause a unit to stop cooling. the model number is gss25psmf, the freezer fan is running the condenser fan is running, unplugged it over night just plugged it back in to see if it would get cold so far not cooling. I removed the panel inside the freezer cant see frost as it had been unplugged. Thanks.
Originally Posted by: denman  compressor does not appear to be running, is cold, no frost on condenser.
This is probably just a terminology problem but there will not be frost on the condenser (coils under the unit). Frost should be on the evaporator ( coils in the freezer). OK sounds like it may be a problem with the compressor or it's start relay. Check that the compressor is getting power. Check the compressor windings. You will need a meter for this. Below are a couple links. The first has better general info, the second has better checking instructions. http://www.applianceaid.com/frig.htmlAppliance Repair Guide: How To Fix a Refrigerator - ACME HOW TO.comIf you do not own a meter, I would suggest you purchase a one. You can get a decent digital multimeter for under $20.00. You do not need fancy though it is nice if the leads are a couple feet long. If it saves ordering one unnecessary part it has paid for itself and you end up owning a useful tool. Most places will not let you return electrical parts so if you order it, you own it. A couple things to watch when measuring ohms and continuity 1. Always remove power from the machine otherwise you could blow your meter. 2. Always disconnect at least one side of any device you are checking. This eliminates the possibility of measuring an alternate/parallel circuit path. 3. When checking for closed contacts and continuity use the lowest scale (Usually 200 ohms). Then try higher scales. This scale is 0 to 200 ohms so if the device you are measuring is 300 ohms this scale would show an open circuit which it is not, you are just measuring outside the scale's dynamic range. There is a good STICKY at the start of this forum about it's use. |
