2 Pages<12
17929
#11 Posted : Tuesday, August 19, 2008 2:09:50 AM(UTC)
17929
Model #KSRG25FKSS04
17929
#12 Posted : Tuesday, August 19, 2008 5:05:03 AM(UTC)
17929
Too warm in back to freeze. Tried switching leads again, unable to get water to ice maker using door water dispenser.
17929
#13 Posted : Tuesday, August 19, 2008 10:10:54 AM(UTC)
17929
Does this mean the sending unit is bad?
jkeenan
#14 Posted : Tuesday, August 26, 2008 10:10:13 AM(UTC)
jkeenan
I check the valve by swapping the leads as suggested. This Activated the icemaker and caled for water. I assumed the Ice Maker was faulty and ordered a replacement from APP. Everything is installed but the tray will not fill.
I checked the fill tube and it is not frozen. Any suggestions would be greatly appreciated.
libertyappl
#15 Posted : Tuesday, August 26, 2008 11:01:05 AM(UTC)
libertyappl
When you swapped the leads and got water into the icemaker did you get water thru thr door as well. If no its probably your valve.
Nat
Ice maker won't fill with water automatically (Refrigerator & Freezer Repair)
by tracymckibben 9/8/2016 6:19:30 PM(UTC)
Ice maker won't fill with water (Refrigerator & Freezer Repair)
by arctic123 12/6/2012 5:26:07 PM(UTC)
ice maker won't fill (Refrigerator & Freezer Repair)
by krzy1957 7/20/2012 1:04:14 PM(UTC)
ice maker won't fill with water (Refrigerator & Freezer Repair)
by bettyjoe 10/27/2011 10:24:50 AM(UTC)
Whirlpool Ice maker won't fill (Refrigerator & Freezer Repair)
by LabTech 8/3/2009 12:26:08 PM(UTC)
2 Pages<12
