leelim
#1 Posted : 14 years ago
leelim
Hi
The dryer is heating okay from a cold start, it turns off the heat after about 5 minutes. It will not heating at after that till is quite cool, before I will heat again. When I removed the front panel to view the igniter, When it does heat, the igniter will get red hot, light the gas and the dryer will heat but it appears that after the heat turn off or I open the dryer and restart it the igniter turn red hot for about 15 second but no gas coming, thus no heat. The igniter will cycling this pattern about 5-6 times, before it finally ignite and heat up again.
Can you tell me what part may have gone bad and how to diagnose it myself at home. Is there a repair manual available it I want to replace it myself?
Thanks for your help.
Leelim
kayakcrzy
#2 Posted : 14 years ago
kayakcrzy
Replace the coils on the gas valve, and that will do it. A quick and easy, and cheap repair. Tom Appliance Educator, Appliance Parts, Washer and Dryer Parts, Refridgerator and Freezer Parts, Stove and Oven Parts
leelim
#3 Posted : 14 years ago
leelim
While disconnecting the wires from coils, we tripped the circuit (unit were not unplug). Now, the ignitor glows continuesly but no gas flow or flame at all. Not sure what had went wrong? Please advise.
kayakcrzy
#4 Posted : 14 years ago
kayakcrzy
What do you mean continuously? It never shuts off now?????
leelim
#5 Posted : 14 years ago
leelim
Yes. the ignitor come on stay on red and never go off, we reserch a bit and our thought is the flame sensor may has been shorted, as the the resistant is registered as 0 ohm. It that make sense??
kayakcrzy
#6 Posted : 14 years ago
kayakcrzy
Yes, I would agree, about the flame sensor being shorted. Because it should shut the ignitor off, if the gas valve is bad, or the coils on the gas valve are bad. I would go with the flame sensor. So, when you replace it, and the ignitor comes on, and no gas, then shuts off, you could have damaged the gas valve. I would change the flame sensor. I think that will do it. Tom ApplianceEducator.com
