LOUH
#1 Posted : Tuesday, December 14, 2010 1:36:05 PM(UTC)
LOUH
Inside Element Of Lf Double Burner Does Not Work. I Inspected The Element And Could See No Breaks Or Burns. I Had Replaced The Original Switch Previously So I Thought It Was The Switch Again. I Put In A New Switch With Same Results. Suggestions ? ? ?
#2 Posted : Tuesday, December 14, 2010 1:49:01 PM(UTC)
Replacement parts for WHIRLPOOL KECC563HBL0 | AppliancePartsPros.com
I am afraid just looking at it is not good enough.
Many of these elements have a limiter built in, perhaps this is blown.
You will have to measure it with a meter, should be 40 to 50 ohms.
LOUH
#3 Posted : Wednesday, December 15, 2010 8:13:04 AM(UTC)
LOUH
You were right. Inside element was open. Replacement ordered.
Thanks Much !
#4 Posted : Thursday, December 16, 2010 2:52:25 AM(UTC)
You are welcome
And thanks for getting back to us. Now when others search for a similar problem they will see what actually worked instead of just suggestions about what could be the cause.
