Replacement parts for FRIGIDAIRE FER211AS2 Frigidaire/dryer | AppliancePartsPros.com [COLOR="Blue"]
Need to no if there is a part that i can buy or order to make the heater coil start to work again[/COLOR]
You have to do some troubleshooting as there are many things/parts that can cause no heat.
You will need a meter.
First check the power.
Then use a meter and check the heater and thermostats.
Here is a good link to basic dryer repair info.
http://www.applianceaid.com/dryers.html
Power Check Try flipping the breaker off/on slowly a couple times, sometimes you can loose half the line without actually tripping the breaker.
If this does nothing, check the voltage at the plug
L1 to L2 should be 240 volts
If OK
If OK
[COLOR="Red"]
Be careful as 240 volts is lethal !!! [/COLOR]
Meter If you do not own a meter, I would suggest you purchase a one. You can get a decent digital multimeter for under $20.00. You do not need fancy though it is nice if the leads are a couple feet long.
