I need a translation of fault code F6 on a Kenmore microwave. Unit is totally inoperable, low buzz when door is closed.
I have a Kenmore Micro with the same F6 problem! I see 2 requests for help on this site but no resolutions for either one.
Try this test.... F6 Microwave relay failure 1. Unplug microwave oven or disconnect power.
2. Check wiring to Relay 4903 for short circuits.
3. If wiring is OK, replace electronic control. 4. Plug in microwave oven or reconnect power
All you need to do is slap the inside right part of the microwave while it is unplugged. Then plug it back in and it will work.
