nirit2002
#1 Posted : Wednesday, August 20, 2008 3:43:55 PM(UTC)
nirit2002
My 20yr old caloric oven (model no. PTR 645 UN) is no longer ingniting. I assume it is the spark module. The spark module says Harper Wyman Kool Lite model no. 6521. Is there any way to replace this? Thanks!
libertyappl
#2 Posted : Wednesday, August 20, 2008 7:39:39 PM(UTC)
libertyappl
This one might work take a look at it.. it's a Harper Wyman #6520
Part number AP210258
Hope that helps.
Nat
nirit2002
#3 Posted : Friday, August 22, 2008 1:27:16 PM(UTC)
nirit2002
Nat,
The part you recommended only has ports for 4 wires. The spark module in my stove has a total of 6 wires. My stove has 5 burners. Any other suggestions?
libertyappl
#4 Posted : Friday, August 22, 2008 2:05:21 PM(UTC)
libertyappl
Since the actual part is no longer available I would use the one I told you about and just tie the two least used burner wires together and attach to one port.
That's the best suggestion I can give you.
Hope that helps you
Nat
#5 Posted : Friday, August 22, 2008 3:19:22 PM(UTC)
If you can post a picture of the original part, we can probably match it up.
nirit2002
#6 Posted : Monday, August 25, 2008 10:21:37 AM(UTC)
nirit2002
Hi Gene,
I tried to post pictures of the spark module but the web site doesn't seem to be letting me do it. Is there an email I can mail them to? Thanks for your help. Nirit
#7 Posted : Monday, August 25, 2008 11:18:28 AM(UTC)
After you clicked on the "quick reply" button you have to click on the "Go Advanced" button and scroll down to "Attach files". Click on the "Manage Attachments" button. Browse and upload your picture.
