2 Pages<12
Meg1223
#11 Posted : Monday, August 25, 2008 9:55:17 AM(UTC)
Meg1223
Originally Posted by: abadfish66 Go to Quoted Post
I think that is your problem, If you don't get that shaft back in through the flapper assy inside the pump assy, than this will happen. If you want to try to get it back in properly, you will need to remove the motor/pump assy and do it this way. If you can't get it in, and I never have been able to, you will need to install a new motor/pum assy.
Upon further thought - does this mean you would have to replace the whole motor/pump assembly anytime you replaced the pump drain valve shaft seal - which you have to replace by taking off the shaft - and by the way, the seal is a part that is suggested to also be replaced when you replace the drain solenoid...
abadfish66
#12 Posted : Monday, August 25, 2008 10:14:46 AM(UTC)
abadfish66
Normally you don't remove the shaft when replacing the seal, otherwise you run into this problem, and now you may have to replace the pump/motor, unless you can figure out a way to get the shaft back into the drain flapper.
Meg1223
#13 Posted : Monday, August 25, 2008 11:18:12 AM(UTC)
Meg1223
So then how do you get the seal on if you don't remove the shaft?
abadfish66
#14 Posted : Monday, August 25, 2008 11:46:32 AM(UTC)
abadfish66
There is a ring on the shaft you take of, you can then slide off the old seal and put the newone on, then put the lock ring back on
Guest (11)
2 Pages<12
