Original icemaker went out, hubby bought a new one and installed it last week. It made 1-2 batches of ice, then stopped. It cycles as though it's trying to make ice, the little lifters raise and everything, but it doesn't fill with water. He replaced the water line also, still not ice. Ideas?
What is the complete model number of the refrigerator?
Does it have a water dispenser? If it does how it works?
No water dispenser. It's a basic top freezer model. #106.70172990
Thanks so much
If there is water to the refrigerator, then the problem most likely is a bad water inlet valve on the back of the refrigerator. - The water inlet valve Part number: AP3961809
