russprogress
#1 Posted : Thursday, December 2, 2010 11:55:58 AM(UTC)
russprogress
Our dishwasher (Roper built-in) (WU5750B1) has been acting very erratic the last few weeks and I am looking for suggestions as to what could be failing.
Last week, one operation did not drain at all, another operation the timer just made EXCESSIVE clicking noises and no wash occurred.
Today: First attempt, timer rotated using proper time frame with normal mechanical clicks, but no operations occured for the entire 'cycle'
Second Attempt, proper operation as should be, with minor water puddle in bottom (very little)
Additional notes....Timer does not feel stiff or unusual, We have only had a total of two cycles that did not drain over the course of about twenty cycles, The clicking timer with no other operations has occurred three times now.
My first guess is that the timer may be getting worn? Obviously I do not want to inivest in a new timer if that is not the issue. Since (as I understand it) the timer sends all the power inputs to the components at the required time I am assuming that this may be the problem since certain cycles, nothing has operated.
HELP please.
#2 Posted : Thursday, December 2, 2010 1:25:49 PM(UTC)
Originally Posted by: russprogress Go to Quoted Post
...the timer just made EXCESSIVE clicking noises and no wash occurred...
Sounds like the problem is a bad timer. If you would like to verify it, wait until it will do it next time and try to push the timer knob in and pull it out without opening/closing the door. If the dishwasher will start, replace the timer.
- The timer Part number: AP3010744
russprogress
#3 Posted : Thursday, December 2, 2010 4:15:23 PM(UTC)
russprogress
Gene, Thanks for the input, I will mention this to my wife also so that one of us can try this.
#4 Posted : Friday, December 3, 2010 2:34:09 PM(UTC)
russprogress
#5 Posted : Monday, December 13, 2010 12:19:56 PM(UTC)
russprogress
I went ahead and installed a new timer in this dishwasher.......No help it is still erratic in its operations.
Could there be a problem with the door switch? or the door switch wiring?
Any help would be greatly appreciated.
#6 Posted : Monday, December 13, 2010 12:46:29 PM(UTC)
Possible the problem is a bad push button selector switch. You can check it according to the attached wiring diagram.
If this is the problem unfortunately this part is no longer available.
If you ordered the timer from Appliance Parts Pros then you can return it with no problem.
File Attachment(s):
Wiring Sheet - WU5750.pdf (46kb) downloaded 5 time(s).
