rangerjake72
#1 Posted : Monday, December 13, 2010 8:50:06 AM(UTC)
rangerjake72
hello all,
my Frigidaire Gallery front load washer lately has been leaving the clothes soaking wet when it finishes. I observed it at the end of the cycle, it rotates a few times but doesn't spin up to speed, i pulled the drain line off and cleared out debris from the strainer, it sounds like the water pump is working though no water exits the drain line
#2 Posted : Tuesday, December 14, 2010 2:25:59 AM(UTC)
Here are tour parts includes a wiring diagram.
Replacement parts for FRIGIDAIRE GLTF2940ES3 Frigidaire/washer | AppliancePartsPros.com
Here is the tech sheet it has a more legible copy of the wiring diagram plus diagnostics
http://manuals.frigidaire.com/prodinfo_pdf/Webster/134730700.pdf
And here is a manual that looks like it covers your unit
http://frigidaireservicetips.com/pdfs/490_3cuftHorizontalAxisWasherSM.pdf
Confirm that the pump is running.
If yes then check the drain hose for a plug.
If hose is OK then odds are the pump is toast or jammed or the flapper is messed up
Part number: AP4359998
Click on the picture for more views/info on the pump.
It is not uncommon for these pumps to go.
You will have to do more troubleshooting for the spin problem
