pacoflyer
#1 Posted : Sunday, August 24, 2008 4:44:05 PM(UTC)
pacoflyer
Our 4 yr old sub zero 685 is again not working properly. The buttons for the ice & water simply turn the coutesy light off when pushed. The unit is not frozen and turning it completly off to re set it , does nothing.
Any advice ?
thanks very much
jdappl07
#2 Posted : Sunday, August 24, 2008 6:47:54 PM(UTC)
jdappl07
check the wire connections at the top of the unit if there are good i would suggest calling a pro
