irobertg
#1 Posted : Saturday, December 11, 2010 9:48:28 AM(UTC)
irobertg
I replaced what I thought was the only parts needed to make to ridge door close properly. I was wrong, the door still does not close the way it did when new.
I replaced the stop and the plate on the bottom hinge. I have to physically close the door and hope it stays shut.
What am I missing???:rolleyes:
#2 Posted : Sunday, December 12, 2010 4:57:31 AM(UTC)
Replacement parts for FRIGIDAIRE FRS26LH5DS3 Frigidaire/refrigerator | AppliancePartsPros.com
Did you replace the lower cam/bearing on the door itself.
If not that could be your problem.
Check that the unit is level front to back or leaning slightly to the back.
Should be level side to side.
Check that the door seal on the hinge side is not grabbing to the frame folding back a bit and acting like a spring.
A common fix for this is a light coating of vaseline or white lithium grease so that it slides on the frame.
