rstuckey5
#1 Posted : Saturday, December 11, 2010 1:01:23 PM(UTC)
rstuckey5
I just changed the timer on this dryer. The old was only working when pressure applied & angle changed. The new timer does not engage the "intellidry" mode hence the dryer continues to run even when clothes are dry. It did work with old timer. They are sending a replacement timer, but it is the same part #. It is FSP 33002803 could there be another pt# for the "intellidry" model? thank you for any help
jquinn
#2 Posted : Monday, May 27, 2013 8:08:37 AM(UTC)
jquinn
Did you ever resolve this problem?
I have a different model, but the exact same problem. I had to replace the timer because I couldn't even start the dryer with the old one. The first timer they sent turned on but then the timing part didn't work in any mode. Now they sent me another timer, and Timed Drying works, and the "Less Dry" mode on "Regular Dry" (IntelliDry) cycle works, but anything higher (i.e., requiring more time) does not work for the "Regular Dry" mode - the timer just stays in the same spot and doesn't turn.
Any help would be appreciated.
