jimgerard
#1 Posted : Saturday, December 11, 2010 10:38:59 AM(UTC)
jimgerard
I believe my control panel has burnt out. How do I replace it?? Do i have to take the entire double oven out to replace the panel??
#2 Posted : Saturday, December 11, 2010 12:13:46 PM(UTC)
Here is your parts breakdown
Replacement parts for WHIRLPOOL GBD277PDS10 27`` BUILT-IN ELECTRIC DOUBLE OVEN CONVECTION - UPPER OVEN SELF-CLEAN (GOLD LINE | AppliancePartsPros.com
Here is a manual
https://secured.whirlpool.com/Service/SrvTechAdm.nsf/2cd44500d572193285256a45004fd9d6/7d69e72584ddde3385256a7e00524e76/$FILE/8178007.pdf
Why do you think it is burned out?
If it is totally dead it could be the fuse (Page 5-4)
OR
The transformer
Could also be the board but check these first.
Be sure to flip the breaker off when working on the oven.
240 volts is lethal!!!
I actually also check with a meter just to be extra sure the power is off.
