I have a GE Profile Artica (PSS26NGSBWW) and the ice and water dispenser were not dispensing. Ice was made but when you attempt to get ice or water you could hear the refridgerator fan slow, the lights would all dim and nothing would happen. This would stay this way until the light went off, then the fan came back on and all the LEDs on the front panel became bright.
I took out the light bulb from the dispensing area and this problem sort of went away. Now, sometimes when you try to get ice this same scenario described above happens.
Right now I'm just leaning toward needing to replace the main board behind the front panel. Am I on the right track?
You definatly need to replace the main board, and your problems will go away.
