bvrablic
#1 Posted : Sunday, August 24, 2008 5:46:11 AM(UTC)
bvrablic
timer advances but does not run washer in regular cycle---everything works in delicate--IS THIS THE TIMER?? Which one do i need to order?? how do i change it--thank you
libertyappl
#2 Posted : Sunday, August 24, 2008 8:43:26 PM(UTC)
libertyappl
Sounds like a timmer issue, can you double check the model number and I can get you the correct part number.
Nat
Amana Washer Timer (Washer Repair)
by kuffsford 9/2/2010 11:00:12 AM(UTC)
