2 Pages12>
zahoorshah
#1 Posted : 14 years ago
zahoorshah
Hello,
My GE space maker xl1800 model no: JVM-1851BH06 is not heating and turntable is not moving but some time it moves very slowly. Can you please let me know how to fix it.
Thanks,
Zahoor
#2 Posted : 14 years ago
Zahoor,
Does it make any noise when it's on or it's silent?
If it does, is this noise sounds like normal?
Here are the breakdown diagrams and Replacement parts for General Electric JVM1851BH06 Counter top microwave | AppliancePartsPros.com
zahoorshah
#3 Posted : 14 years ago
zahoorshah
yes - the sound is little hard than normal like humming noise
#4 Posted : 14 years ago
Remove the microwave from the cabinet. Remove the microwave outer case.
Remove the wires from the high voltage transformer primary winding and check for 120 VAC between these wires while the control calls for heat.
Post the results.
zahoorshah
#5 Posted : 14 years ago
zahoorshah
Hi Gene,
I removed the MW and checked the voltage it says only 4. can you please see the pic and let me if i am doing correct?
zahoorshah attached the following image(s):
#6 Posted : 14 years ago
You did it wrong. The transformer primary winding is connected to the wires coming from the control board or door switches. You went to the secondary (high voltage) or filament windings and it is VERY DANGEROUS.
I'm afraid you can electrocute yourself. It is better if you'll hire a pro to do it for you.
zahoorshah
#7 Posted : 14 years ago
zahoorshah
let me try again with correct wires and will let you know
zahoorshah
#8 Posted : 14 years ago
zahoorshah
Hi Gene,
I checked the correct wires and there is no 120 V. can you please help
#9 Posted : 14 years ago
Did you close the door while performing this test?
If you did and the microwave was on then the problem most likely is a bad control board. The only thing confusing me is a humming noise which is not connected to the control board.
- The control board Part number: AP3883439
zahoorshah
#10 Posted : 14 years ago
zahoorshah
Yes the door was closed while testing and i test again and now meter was showing 136 volts for 10 sec and then zero volts. and some wire burning smell too.
2 Pages12>
