bpbuba711
#1 Posted : Friday, December 10, 2010 3:21:57 PM(UTC)
bpbuba711
We replaced the overload switch. Still not up to par. It is a little cooler but nothing like it should be. What else could we possibly replace? The commpressor kicks in fine and we cleaned the coils under the fridge. This is a top/bottom:( Please help!!
#2 Posted : Saturday, December 11, 2010 12:24:28 AM(UTC)
I could find no info on an adb2533deq.
Are you sure it is not a abd2533deq whose parts breakdown follows.
Replacement parts for AMANA ABD2533DEQ REF - BOTTOM MOUNTS | AppliancePartsPros.com
There does seem to be a problem with the above as the wiring diagram at the end shows a manual temperature control while the parts show electronic.
Please confirm the model number and what typ of controls you have.
[COLOR="Blue"]We replaced the overload switch.[/COLOR]
Which switch, the overload on the compressor or the defrost thermostat etc.?
[COLOR="Blue"]What else could we possibly replace? The commpressor kicks in fine and we cleaned the coils under the fridge.[/COLOR]
Need more info as to what are the symptoms.
Is the compressor cycling?
Are there any strange noises?
You say it is too warm but what is too warm ? The freezer and/or the fresh food section?
Can you check with a thermometer, the temperature in the freezer and fresh food sections?
Freezer should be 0 to 5 degrees F, fresh food close to 40 degrees F.
Is the evaporator fan running?
Is the condenser/compressor fan running?
