AppliancePartsPros.com
Appliance Repair Help
Dishwasher Repair
Bosch dishwasher won't drain, power surge problems?
This machine (Bosch SHE44C) has started giving us problems ever since we had a major power surge in April due to power company error. The costs of proving the cause of the appliance to malfunction exceed the amount they are willing to reimburse us! So please, hellpp! Smelled a slight burning electrical smell, now machine won't drain even in Cancel Drain mode tho machine makes noises as if it's trying to. Water is still soapy. Could this be caused by an electrical failure? Is there a troubleshooting guide available for this model anywhere? Previously my husband had to replace the main electrical connection as the connection was fried -- did not occur instantly at power surge but finally fried over 2 months time. Machine then worked fine for 6 weeks before this latest problem popped up. Could it be the problem? Thanks for any help, especially in regards to finding info so we can troubleshoot & fix the problems that are beginning to arise. ~ victoria vcalkins attached the following image(s):
Gene,
The model number is correct. Purchased at Sears. Manual includes these model #s on the cover: SHE44C, SHE46C, SHE47C, SHE56C, SHU43C, SHX46A, SHX46L, SHX43E, SHV46C.
Thanks for the link.
~ victoria
Victoria,
You should look for the model number on the right side of the door. Manual book designed for a few different models and numbers listed there are incomplete.
Yes, that's where the number came from. The model number in its entirety is SHE44C02UC/38.
Did you perform the troubleshooting yet? Post the results.
We also can't get our Bosch dishwasher to drain. Sporadically will work and then stops again. Repair people can't find anything wrong and say it has to do with electrical reset, but we can't figure out the mechanism.
Susan,
It is very hard to diagnose any kind of an intermittent problem, especially if it would not show up at the time when a tech is next to the appliance.
This site Rocks! I also have an SHE44C02uc which intermittently would not drain and seem to continue in wash mode for a very long time. Same symptoms as described. I found a reference to another Bosch Model referring to a bad solder connection on the heater relay. Sure enough, same problem, destroyed solder connection. Trickest part of finding the problem was openeing the case covering the board....kind of makes me think they didnt want me (the slightly above average home owner) looking.
The electronics are covered by a 5 year waranty. This seems to be a known issue ( if you can troubleshoot with Google), suppose there is any chance of warranty coverage (especially for a home owner repair)?
And the answer is ...NO....the BOSCH manual clearly states the warranty will become null and void...so much for a 5 year warranty. I have formed my opionion regarding BOSCH products. The failure of the heater control relay is clearly a fairly common problem. After paying a premium for the washer it fails after 2 years. MY GE lasted for 13. Go figure.
No, in the plans for Sunday-Monday this week.
Thank you for retaining an interest,
~ victoria
Dishwasher Repair
