Hello, I am brand new to this forum. I have a LG dishwasher Model LDF8812ST that I am having problems with and am looking for a service manual, advice, and suggestions on how to fix this dishwasher.
This Dishwasher does not display any error code.
Here is what it does do: All lights appear to work, can select any mode and that button lights up, will let water in the tub, will pump the water out only when you turn the power off and back on again.
What it does not do: Spray water on the dishes, motor can not be heard running or humming.
Thanks in advance, Chuck
[FONT='Times New Roman']Ok, Downloaded another models service manual. I have performed the test from the front panel. All functions work except the pump motor. (Motor is sold complete as an assembly or motor alone. I am going to do the whole assembly). I took the top portion of the sump apart to make sure that there were no parts to keep it from turning freely and there was not motor can be turned by hand. Before replacing the sump assembly I want to make sure the motor is bad. Has any one ohmed out one of these motors. What is the range of continuity that I am looking for (5 [/FONT][FONT='Times New Roman']Ω[/FONT][FONT='Times New Roman'], 300 [/FONT][FONT='Times New Roman']Ω[/FONT][FONT='Times New Roman']) and from which wire colors do you OHM[/FONT]
