2 Pages12>
this_is_nascar
#1 Posted : 14 years ago
this_is_nascar
My eyes are shot. I've been reading related messages for hours now, but decided to post my specific issue. A couple week ago, I noticed frost on the back wall of the freezer. Additionally, I had a frozen layer of water on the bottom of the freezer compartment. I removed the back panel, defrosted with a hair dryer and ran hot water down the drain hole, since that was totally frozen solid. I got it to the point where I heard the water running thru the tube, into the drain pan. Put everything back and I thought "problem solved".
Today, I noticed even more frost on the back wall of the inside freezer. I do not have frozen water on the bottom like last time. This, I think, is telling me that this problem is a bit different. In my 1st problem, the unit was defrosting (because I got that layer of ice on the bottom), but wasn't draining due to a frozen hole. In this case, it doesn't appear I'm defrosting at all. Maybe I wrong and wasn't defrosting in either case.
I've read about somehow manually forcing a defrost cycle or something like that. I don't know how to do that. Also, something about tricking the defrost timer to engage. I'm thinking, based only on what I've read so far, that my defrost heater or defrost timer or defrost thermostat is shot. How do I go about narrowing it down?
this_is_nascar
#2 Posted : 14 years ago
this_is_nascar
Anyone? Please.
#3 Posted : 14 years ago
Here we go
Here is your parts breakdown
Replacement parts for WHIRLPOOL ET1CHMXKQ05 REFRIGERATOR | AppliancePartsPros.com
First remove the evaporator cover in the freezer so you can see the coils.
Do not let them de-ice.
If they are heavily iced/frosted over you have a defrost problem.
If yes.
Manually force a defrost cycle by turning the defrost timer cam (Item 4 in Section 3) till the fans and compressor turn off.
There is usually a hole in the cover to let you do this with a screw driver.
Note: The cam only turns in one direction.
Now check the defrost heater to see if it is on.
Be careful you do not want to burn your fingers.
If the heater is on then the timer needs replacing, re: it is probably stalling during it's rotation so is never getting into a defrost cycle.
If not on.
Unplug the unit.
Remove the wire for one side of the heating element (Item 4 in Section 4) from the wiring and measure it for continuity, usually around 20 ohms or so.
If the heater is OK
Remove one wire to the defrost thermostat and measure it, should be 0 ohms when frozen. Note that it opens just above freezing so must be frozen to check it.
Also inspect it, if it is bulged at all replace it even if it measures OK.
I could not see it in the parts breakdown. It should be clipped onto the evaporator coils. It hay even be hard wired into the heater.
If both the above are OK then odds are the defrost timer contacts are toast.
Best way to test this is a live test to see if you have 120 volts across the heater/defrost thermostat combo.
this_is_nascar
#4 Posted : 14 years ago
this_is_nascar
Thanks a bunch. It looks like this references a service manual or something as to procedures or locations. Is that the case and if so, where can I get that document? I reall appreciate the help.
#5 Posted : 14 years ago
The part number / section refer to the link in my post.
this_is_nascar
#6 Posted : 14 years ago
this_is_nascar
Got it, thanks. Looks like that defrost timer is within that panel that's on the roof of the refrigerator and I'll have to take that panel down, unless there's access straight thru the panel.
this_is_nascar
#7 Posted : 14 years ago
this_is_nascar
Good news. I was able to access the dial on the defrost timer without taking any off. A simple screwdriver up into the hole, turning clockwise until the fan shut off, immediately put me in defrost mode. The heater element is definitely working. Don't ask me how I found out. :mad:
Anyway, I'll order the defrost timer and perform a manual defrost once a day until I get it installed. I hope that's not to big of a deal to replace. If you have any helpful hints on tackling that job, I'd appreciate it.
Thanks again for all your help.
#8 Posted : 14 years ago
Usually it is undo a screw or two then pull the console forward or back to release a couple clips.
The following may help even though it is not for your specific unit.
https://secured.whirlpool.com/Service/SrvTechAdm.nsf/2cd44500d572193285256a45004fd9d6/b3ebb43c05123bb185256a8e0050f068/$FILE/4322309.pdf
this_is_nascar
#9 Posted : 14 years ago
this_is_nascar
OK great, thanks. I was just concerned about stuff falling and popping out like springs or something.
this_is_nascar
#10 Posted : 14 years ago
this_is_nascar
My story gets more intriguing, to me anyway. This morning I did my normal manual defrost by using a screwdriver to turn the cam in the defrost timer. I turn it until the fan went off, just like I did the last couple of times. The plan was to wait 20-30 minutes then go back and turn the cam again until the fan came on. I got busy and after 40-minutes or so went back to turn it back on and the fan was already back on and running. I had done nothing to the cam/timer to make it come back on.
Does this mean that my timer is now doing what it's supposed to do and no longer requires replacing?
2 Pages12>
