Ray A
#1 Posted : Friday, August 22, 2008 1:36:50 PM(UTC)
Ray A
I have a kitchen aid dishwasher that was used 2 weeks past its 1 year warrantee and it started leaking. I finally removed the motor and pump, inspected for cracks because the water was pouring out. from the pump area. I ordered and installed a Volute seal and still leaked. When I took it apart to put the new seal in I noticed a rust spot between the Volute Back and Motor. I want to confirm there is a seal on the Volute Back? Should I order the Impeller assembly (part #22 in picture) or whirlpool number AP3738238. I also would like to know how to remove the Impeller? Thank you for your help.
libertyappl
#2 Posted : Friday, August 22, 2008 2:13:05 PM(UTC)
libertyappl
The impeller screws on and it's probably pretty tight. You should also order part numbers #22 & 30 when the seal is replaced.
Hope that helps.
Nat
Ray A
#3 Posted : Friday, August 22, 2008 2:15:29 PM(UTC)
Ray A
is the impeller a reverse thread? do the impellers always screw on?
libertyappl
#4 Posted : Friday, August 22, 2008 2:18:11 PM(UTC)
libertyappl
yes they usually do screw on and if memory serves it is revers threaded.
Nat
Ray A
#5 Posted : Friday, August 22, 2008 2:34:56 PM(UTC)
Ray A
Can the seal leak water?
libertyappl
#6 Posted : Friday, August 22, 2008 6:51:54 PM(UTC)
libertyappl
If it's twisted, gets something behind it or cracked then yes, just like a seal in a car, over time they can leak
Guest (4)
